[GRASS-dev] r.unpack: unhelpful error message when projection info does not match
Luca Delucchi
lucadeluge at gmail.com
Thu Feb 27 02:32:48 PST 2014
On 26 February 2014 18:04, Markus Neteler <neteler at osgeo.org> wrote:
Hi all
> ... back to this topic, I would be happy to find a solution for US vs
> UK English:
> GRASS 7.0.svn (patUTM32):~ > r.unpack x60030_2000.green.histo2000_g.pack
> WARNING: Difference between PROJ_INFO file of packed map and of current
> location:
> - name: Universal Transverse Mercator
> + name: Universe Transverse Mercator
> proj: utm
> datum: wgs84
> ellps: wgs84
> zone: 32
> no_defs: defined
> WARNING: Difference between PROJ_UNITS file of packed map and of current
> location:
> - unit: metre
> + unit: meter
> - units: metres
> + units: meters
> meters: 1
> ERROR: Projection information does not match. Aborting.
> r.unpack calls the Python core function compare_key_value_text_files()
> http://grass.osgeo.org/programming7/namespacepython_1_1script_1_1core.html#a3ad1670d5f7b4759935d4b38292fa7af
> and then does the comparison key by key (so, it fails here).
> I think that we need to polish the language differences in r.unpack
> prior to the comparison. Maybe via lookup dictionary which can be
> expanded in future when more cases come up?
> Universe Transverse Mercator --> Universal Transverse Mercator
> metre --> meter
> metres --> meters
> kilometre --> kilometre
> kilometres --> kilometres
> See also the corresponding C functions:
> http://trac.osgeo.org/grass/browser/grass/trunk/lib/gis/proj3.c?rev=58633#L48
> The same fix would then be needed in v.unpack.
I solved the problem for units and projection system in r59147.
The is stil a bug in compare_key_value_text_files because if second
file has more keys this is not recognize.
I would like to add at line 913 this:
if dict_a.keys() != dict_b.keys():
return False
but this could broke all the system of compare_key_value_text_files function
what do you think?
> Markus
ciao
Luca
http://gis.cri.fmach.it/delucchi/
www.lucadelu.org
