Pietro wrote: > libgis.G_set_window(c_region) G_set_window() changes the region for the current process. To modify the WIND file[1], use G_put_window(). [1] or the named region specified by the WIND_OVERRIDE environment variable, if that is in effect. -- Glynn Clements <glynn at gclements.plus.com>
