[GRASS-dev] r.unpack: unhelpful error message when projection info does not match
Fri Feb 28 21:21:53 PST 2014
Luca Delucchi wrote:
> I would like to add at line 913 this:
> if dict_a.keys() != dict_b.keys():
>     return False
The ordering of the elements in the list returned by .keys() isn't
defined. E.g. for some dictionary d,
	d.keys() == d.copy().keys()
can be (and typically is) False.
Convert the keys to sets, i.e.
	if set(dict_a.iterkeys()) == set(dict_b.iterkeys()):
	    return False
Or sort them; I'm not sure which is faster overall.
Aside from that, I don't think that compare_key_value_text_files()
(and the functions it uses) belongs in grass.script.core; they're too
specialised. Likewise for create_location().
