[GRASS-dev] [GRASS GIS] #2151: g.gui.* modules which use temporal framework leave processes after exiting
GRASS GIS trac at osgeo.org
Wed Jan 1 17:57:24 PST 2014
 Reporter:  annakrat                        |       Owner:  grass-dev@…
     Type:  defect                          |      Status:  new
 Priority:  normal                          |   Milestone:  7.0.0
Component:  Python                          |     Version:  svn-trunk
 Keywords:  g.gui.animation, temporal, RCP  |    Platform:  Linux
      Cpu:  All                             |
Comment(by wenzeslaus):
 Replying to [comment:3 huhabla]:
 > All the methods that i have tried are not working in case the GUI module
 uses {{{os.fork()}}} to start the module in the background.
 > Why do we need fork() at all? Unix already support job management in the
 shell and it does not work on windows?
 The idea was to start the application in the background (r57388, r57370 -
 r57378 launch GUI in the background). There was also a discussion on the
 mailing list with reasoning that `g.gui.*` should behave in the same way
 as `g.gui`, that these (`g.gui*`) are special cases (''not able to find
 link now'').
 While [source:grass/trunk/gui/wxpython/core/utils.py#L1053  GuiModuleMain]
 is using Python `os.fork`, `g.gui` is using
 [source:grass/trunk/lib/gis/parser.c#L796 G_spawn] from `grass/spawn.h`.
 When the generated GUI for a module is shown (`v.pack` or `g.region
 --ui`), no special functionality is provided and it blocks terminal unless
 you use `&`.
 > If we really need it, can this be implemented in a better way?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2151#comment:5>
