[GRASS-dev] [GRASS GIS] #2151: g.gui.* modules which use temporal framework leave processes after exiting
GRASS GIS trac at osgeo.org
Fri Jan 3 13:09:32 PST 2014
 Reporter:  annakrat                        |       Owner:  grass-dev@…
     Type:  defect                          |      Status:  new
 Priority:  normal                          |   Milestone:  7.0.0
Component:  Python                          |     Version:  svn-trunk
 Keywords:  g.gui.animation, temporal, RCP  |    Platform:  Linux
      Cpu:  All                             |
Comment(by huhabla):
 Replying to [comment:9 annakrat]:
 > Replying to [comment:8 huhabla]:
 > > The patch is not applied yet, since it does not solve the issue that
 the child process is still alive. Maybe an explicit os.exit() should be
 added to g.gui.timeline? How about an exit button?
 > os.exit would close the whole wxGUI when the timeline tool is called
 from the wxGUI. Exit button would not solve anything, it just does the
 same as the standard x close button or Alt+F4. I tried it to be sure and
 there is no difference. I think you can commit your changes, it's
 improvement. Could the problem come from the matplotlib? Maybe I am using
 it in an incorrect way.
 I have applied the patch and included an explicit kill call in the
 destructor of TimelineFrame, see r58597. The kill signal will only be send
 if g.gui.timeline works in stand-alone mode (hopefully, please cross-check
 that).
 Killing the process is a crude solution, but i have no better idea how to
 avoid orphaned daemon g.gui.timeline processes.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2151#comment:10>
