[GRASS-dev] [GRASS GIS] #2156: Parser does not honor the dash (-) means stdout convention
GRASS GIS trac at osgeo.org
Mon Jan 6 11:30:48 PST 2014
 Reporter:  wenzeslaus                    |       Owner:  grass-dev@…
     Type:  defect                        |      Status:  new
 Priority:  trivial                       |   Milestone:  7.0.0
Component:  Parser                        |     Version:  svn-trunk
 Keywords:  stdout, r.colors.out, m.proj  |    Platform:  Unspecified
      Cpu:  Unspecified                   |
Comment(by neteler):
 What is the scope of using a hyphen as filename to then try to confuse the
 parser (which
 fights perhaps with the shell at the same time)?
 In my experience the probability to find a file with "-" as filename is
 really low.
 Perhaps not the top priority in the remaining parser issues to be fixed
 Likely GRASS did not create it, at least not for me while I am also using
 the
 aforementioned modules.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2156#comment:1>
