[GRASS-dev] area measurements
Anna Petrášová
kratochanna at gmail.com
Mon Jan 6 17:41:42 PST 2014
Hi Vincent,
just FYI, I fixed (and Markus) the problems with units, so you should now
be able to use 'metres' as well (but in GRASS 7 only).
On Sun, Jan 5, 2014 at 4:05 PM, Anna Petrášová <kratochanna at gmail.com>wrote:
> Hi Vincent,
> On Sun, Jan 5, 2014 at 10:14 AM, Vincent Bain <bain at toraval.fr> wrote:
>> Le dimanche 05 janvier 2014 à 08:42 -0500, Anna Petrášová a écrit :
>> > Vincent,
>> > On Sun, Jan 5, 2014 at 5:19 AM, Vincent Bain <bain at toraval.fr> wrote:
>> > Hi Anna,
>> > I just tested on r58611. Unfortunately it fails :
>> > could you try m.measure separately? Launch it from gui command line or
>> > menu so that you have the interactive adding coordinates from map
>> > display. Could you post the result of m.measure with and without -g
>> > flag?
>> Yes, here it is with four points describing a 1 km side square :
>> m.measure
>> coordinates=922000,2106000,923000,2106000,923000,2107000,922000,2107000
>> units=meters
>> Length: 3000.000000 meters
>> Area: 1000000.000000 square meters
>> m.measure -g
>> units=meters
>> units=meters,square meters
>> length=3000.000000
>> area=1000000.000000
>> I actually didn't want you to use the units parameter, this is why you
> got reasonable outputs. Without it you would probably get segmentation
> fault. I created a ticket for this:
> http://trac.osgeo.org/grass/ticket/2157
> Having a closer look at my PROJ_UNITS file, I noticed unit was set to
>> "metre" and units was set to "metres". I tried to change these values to
>> "meter" and "meters". And now it works just fine.
> Yes, that makes sense. I was wondering why do you have metres instead of
> meters there?
>> I can't say when and how one can tweak this variable.
>> Do you think this enhancement could be easily backported to 6.4 ?
> Unfortunately not. One thing is the GUI part which I would have to write
> again for grass 6 because although it looks the same, the code of wxGUI is
> quite different. And write it for grass 6 would be more difficult. The
> other thing is that m.measure is only a grass 7 module so I don't know
> which backend should be used for grass 6.
> Regards,
> Anna
>> Yours,
>> V.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140106/daded3e5/attachment.html>
