[GRASS-dev] [GRASS-user] Python error with GRASS 7 on Windows 8
Vaclav Petras wenzeslaus at gmail.com
Tue Jan 7 06:12:11 PST 2014
I'm sorry, Nuno, that you encountered all of these bugs, too much for one
user.
Devs, so, the error in the file is GRASS GIS 6.4.3 (stable release) running
addons module and says:
Unable to fetch interface description for command
'i.landsat.dehaze.bat'.
Details: "C:/Program Files (x86)/GRASS GIS
6.4.3/msys/bin/sh.exe":
C:\Users\Invader\AppData\Roaming\GRASS6\addons;C:\Program
Files (x86)\GRASS GIS 6.4.3\etc\gui\scripts;C:\Invader_B\GRA
SS_Workfolder_01\01_LT4/scripts/i.landsat.dehaze: No such
file or directory
Which seems that there are some problems with path separator since it is
trying to run C:\....;C:\...i.landsat.dehaze file which does not exists
from obvious reasons.
Those involved in #2138, is this what #2138 is trying to solve?
http://trac.osgeo.org/grass/ticket/2138
On Tue, Jan 7, 2014 at 8:34 AM, Nuno Sá <nunocesardesa at gmail.com> wrote:
> Oh sorry, I should have added in the previous response to avoid too many
> emails:
> I have both 6.4.3 and 7 installed at the same time, the first issues no
> errors in any moment with the exception of not being able to call
> i.landsat.dehaze on the gui command console (yes i have used the plugging
> installer to install it). The error log is on the .txt file appended
> Ciao!
> Thank you so much for the help so far, and I'm sorry if I'm causing any
> trouble.
> On 7 January 2014 13:29, Nuno Sá <nunocesardesa at gmail.com> wrote:
>> Hey
>> I don't :'( so the differential diagnosis continues :P
>> On 7 January 2014 13:15, Anna Petrášová <kratochanna at gmail.com> wrote:
>>> On Tue, Jan 7, 2014 at 7:43 AM, Helmut Kudrnovsky <hellik at web.de> wrote:
>>>> >(which I really actually need, i.landsat.dehaze)
>>>> have a look at
>>>> http://grasswiki.osgeo.org/wiki/AddOns/GRASS_6
>>>> and
>>>> http://grasswiki.osgeo.org/wiki/AddOns/GRASS_7/imagery
>>>> https://svn.osgeo.org/grass/grass-addons/grass7/imagery/
>>>> i.landsat.dehaze seems to be available only for grass6 at the moment
>>>> maybe the author (cc'ed) has more insight about this.
>>>> > In this case, I am just forcing the error by trying to install an
>>>> > extension
>>>> beside addon availability, "Settings -> Addons extensions -> Install
>>>> extensions from addons" isn't working in winGRASS7.
>>>> only the the command line version of g.extension is working, e.g.:
>>>> g.extension extension=r.geomorphon operation=add
>>>> Downloading precompiled GRASS Addons <r.geomorphon>...
>>>> Updating metadata file...
>>>> Installation of <r.geomorphon> successfully finished
>>>> (Tue Jan 07 13:41:31 2014) Command finished (2 sec)
>>>> please open a ticket in http://trac.osgeo.org/grass/
>>> this can be again the Python incompatibility issue (the MAXREPEAT
>>> problem). For this issue there is already ticket
>>> http://trac.osgeo.org/grass/ticket/2150
>>> It usually appears when you have also ArcGIS installed.
>>> Anna
>>>> best regards
>>>> Helmut
>>>> View this message in context:
>>>> http://osgeo-org.1560.x6.nabble.com/Python-error-with-GRASS-7-on-Windows-8-tp5096508p5096756.html
>>>> Sent from the Grass - Users mailing list archive at Nabble.com.
>>>> _______________________________________________
>>>> grass-user mailing list
>>>> grass-user at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/grass-user
>> Nuno César de Sá
>> +351 91 961 90 37
> Nuno César de Sá
> +351 91 961 90 37
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140107/6d8d14a8/attachment-0001.html>
