[GRASS-dev] wxPython 3 support
Maciej Sieczka
msieczka at sieczka.org
Sun Jan 12 21:59:16 PST 2014
Hi Anna,
I will try a thing or 2 and report if needed.
I don't think I will have time for systematic tests though.
Maciek
W dniu 13.01.2014 00:31, Anna Petrášová pisze:
> Hi,
> On Sun, Jan 12, 2014 at 5:40 PM, Maciej Sieczka <msieczka at sieczka.org
> <mailto:msieczka at sieczka.org>> wrote:
> Hello,
> Can you please tell what is the status of wxPython 3 support in SVN
> GRASS6 and 7?
> so far I tested grass 6 and 7 with wxpython 2.9 only. I am not sure
> what's the difference between 2.9 and 3 but I hope it's not so big.
> There is a problem on Arch Linux, which has just replaced 2.8 with
> 3.0, and GRASS 6.4.3 says "ERROR: wxGUI does not support wxPython
> 3.0.0.0 yet" to that.
> GRASS 6.4.3 was not yet working with newer wxPython, that's why you get
> the error. Current GRASS 6.4 branch should somehow work although I was
> not able to test the whole wxGUI, so you can expect some glitches. I
> would appreciate if you can test and report errors which can be related
> to new wxPython.
> Trunk G7 and 6 build OK against wxPython 3.0. On a very quick
> runtime check I noticed they frequently throw the following errors
> though:
> G7:
> /opt/grass70-svn/etc/gui/__wxpython/gui_core/goutput.py:__234:
> wxPyDeprecationWarning: Call to deprecated item 'SetVirtualSizeHints'.
> self.outputSizer.__SetVirtualSizeHints(self.__panelOutput)
> Nothing critical, I didn't remove it yet because I'm not sure if it's
> needed with wxPython 2.8.
> (wxgui.py:11592): Gtk-CRITICAL **:
> IA__gtk_widget_set_size___request: assertion 'width >= -1' failed
> IA__gtk_widget_set_size___request: assertion 'height >= -1' failed
> G6:
> (wxgui.py:18284): Gtk-CRITICAL **:
> I think it doesn't really break anything (right?) and it's hard to track
> what's the problem so I usually ignore it.
> Thanks for reporting,
> Anna
> Maciek
> Maciej Sieczka
> http://www.sieczka.org
> _________________________________________________
> grass-dev mailing list
> grass-dev at lists.osgeo.org <mailto:grass-dev at lists.osgeo.org>
> http://lists.osgeo.org/__mailman/listinfo/grass-dev
> <http://lists.osgeo.org/mailman/listinfo/grass-dev>
Maciej Sieczka
