[GRASS-dev] [GRASS GIS] #2162: can't close vector map query results window
GRASS GIS trac at osgeo.org
Mon Jan 13 10:06:13 PST 2014
 Reporter:  msieczka  |       Owner:  grass-dev@…
     Type:  defect    |      Status:  new
 Priority:  major     |   Milestone:  6.4.4
Component:  wxGUI     |     Version:  svn-releasebranch64
 Keywords:            |    Platform:  Linux
      Cpu:  All       |
 r58684 built and running against wxPython 3.0 on 64bit Arch Linux.
 As you can see on the attached screenshot, the query results window
 doesn't have any controls for closing it. The Cancel button does not let
 close it either. In a result, each query (here in digitizer, but the same
 applies to queries on vector maps in the main GUI) leaves such a dangling
 window. They can be closed only by closing their parent map display. This
 completely breaks digitizer and breaks an important feature in the main
 GUI.
 I'm not sure if this is a matter of my desktop environment or GRASS GUI.
 I'm using a stock Gnome 3.10.1. Can anybody reproduce this?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2162>
