[GRASS-dev] [GRASS GIS] #2121: v.rast.stats: allow choice of statistics
trac at osgeo.org
Thu Jan 16 00:41:54 PST 2014
Reporter: mlennert | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.0.0
Component: Vector | Version: svn-trunk
Keywords: v.rast.stats | Platform: Unspecified
Cpu: Unspecified |
Comment(by lucadelu):
Replying to [comment:6 mlennert]:
> Now, one more issue: since recently (r57999), there is the possibility
to abbreviate option values, but this does not seem to work here:
> v.rast.stats blks raster=elevation column=elev
method=mini,maxi,mean,stddev -c
> Processing data (2535 categories)...
> Traceback (most recent call last):
> File "/data/home/mlennert/SRC/GRASS/grass_trunk/dist.x86_64-unknown-
linux-gnu/scripts/v.rast.stats", line 295, in <module>
> main()
linux-gnu/scripts/v.rast.stats", line 261, in main
> i = variables[variable]
> KeyError: 'mini'
> I don't know exactly what's needed to make this work, but it would be
nice if it did.
fixed in r58731, I just check the long name and set it instead the
abbreviate one.
No objections were done for remove the ''e'' flag and add the methods to
''method'' option, so I start to implement it
> Moritz
Luca
Ticket URL: <https://trac.osgeo.org/grass/ticket/2121#comment:9>
