[GRASS-dev] [GRASS GIS] #2169: hardcoded gcc compiler in gem/Makefile
GRASS GIS trac at osgeo.org
Mon Jan 20 05:12:24 PST 2014
 Reporter:  mojca        |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  normal       |   Milestone:  6.4.4
Component:  Default      |     Version:  6.4.3
 Keywords:               |    Platform:  Other Unix
      Cpu:  Unspecified  |
 This is not an issue in `trunk` any longer, but both in the latest release
 (6.4.3) and in `branches/releasebranch_6_4` the file `gem/Makefile`
 hardcodes `gcc` as compiler which is causing some problems in `MacPorts`.
 Here are some other potentially problematic sources with hardcoded gcc:
  * `gui/scripts/g.extension.py`
  * `lib/python/ctypes/ctypesgen.py`
  * `lib/python/ctypes/ctypesgencore/options.py`
  * `lib/vector/rtree/Makefile.alone`
  * `macosx/modbuild/Platform.make.in`
  * `vector/v.mapcalc/Makefile`
  * `vector/v.mapcalc/plugins/Makefile`
 but I don't know when/if these are used.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2169>
