[GRASS-dev] [GRASS GIS] #2175: m.nviz.image: adding transparency_value= changes raster layer stacking order
trac at osgeo.org
Mon Jan 27 14:15:39 PST 2014
order
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.4
Component: Default | Version: svn-trunk
Keywords: m.nviz.image, transparency | Platform: Linux
Cpu: x86-64 |
Comment(by hamish):
Replying to [comment:1 annakrat]:
> This is a duplicate of #2117. You get the same effect in `TclTk`
> Nviz when you click on Draw button instead of Draw current. I
> haven't looked into this yet what's the difference between those
> two buttons.
thanks. in tcl/tk nviz the 'Draw' button at the top re-renders the entire
scene, i.e. all layers of all types. The 'Draw Current' button in the
Raster Surfaces panel just renders the current raster layer (from the drop
down list). So to produce the effect there I usually select the
transparent planar surface, then click the main Clear and Draw buttons,
then click the lower 'Draw current' button to overlay any planar surfaces,
then take a screenshot.
There seems to be a slight difference in behaviour between what Richard
reported for wx #2117 and what happens from the command line: In #2117
setting the transparency to 0 (i.e. opaque) had the rendering order go
back to normal. On the command line that doesn't work, if you use the
transparency_value= option at all (even with 0,0) the rendering order gets
mixed up. In order to get a cutting plane effect from a constant surface
you need to leave off the transparency_value= option altogether. I'd note
that the tcl/tk NVIZ settings allow unset,0-255, with the default as
unset. Perhaps unset != 0, and some test needs to be changed from
if(unset) to if(unset || value == 0) ?
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/2175#comment:2>
