[GRASS-dev] Handling of Python scripts on MS Windows
Vaclav Petras
wenzeslaus at gmail.com
Tue Jan 28 07:07:03 PST 2014
On Tue, Jan 28, 2014 at 6:07 AM, Markus Metz
<markus.metz.giswork at gmail.com>wrote:
> On Mon, Jan 27, 2014 at 12:16 AM, Glynn Clements
> <glynn at gclements.plus.com> wrote:
> > Markus Metz wrote:
> >> On Sat, Jan 25, 2014 at 3:59 PM, Helena Mitasova <hmitaso at ncsu.edu>
> wrote:
> >> > Just a note, given that most of these problems were caused by
> conflicts with python installed by ArcGIS,
> >> > I checked with our GIS support and the latest ArcGIS 10.2 installs
> python2.7 which (I guess) should work with GRASS.
> >> No, there are different versions of Python 2.7, and not all work with
> >> GRASS, see e.g. ticket 2015
> > Any version of Python 2.7 should be suitable for GRASS.
> Not all versions of Python 2.7 are suitable for WinGRASS, see ticket #2150.
Actually, the problem in #2150 is that there is a version mismatch, or mess
is probably a better word: When Python script is called from Python
module/script system association is used (if exists?) and system-wide
python.exe is used, however the Python distribution packages which are used
are from our Python inside GRASS. The current problem is that there is a
incompatibility between Python 2.7.3 and 2.7.4; some import fails because
older system Python library (dll) does not contain MAXREPEAT variable. (To
be honest, now I'm not sure how (dll) library is involved in this. I
remember that even our python.exe was using dll from system Python...)
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140128/6f273b62/attachment.html>
