[GRASS-dev] change linear back to bilinear in grass7 ?
Anna Petrášová kratochanna at gmail.com
Thu Jan 30 12:10:07 PST 2014
So, is there any objection to change it back to bilinear/bicubic? If not I
will change it and correct the manuals as well (revert r57279).
Does anyone know if linear/cubic is used somewhere used correctly, I mean
in the 1-dimensional sense? I couldn't find anything like this.
What about renaming G_OPT_R_INTERP_TYPE to G_OPT_R_INTERP_TYPE_2D just in
case we would ever need to define separate options for 1 or 3 dimension
interpolation?
Thanks,
Anna
On Mon, Jan 27, 2014 at 8:55 PM, Glynn Clements <glynn at gclements.plus.com>wrote:
> Hamish wrote:
> > Is the "bicubic" truly considering x and y separately? i.e. is it
> > actually correct to use the "bi-" prefix with it?
> Yes.
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140130/cbd6b3fc/attachment.html>
