[GRASS-dev] Handling of Python scripts on MS Windows
Thu Jan 30 16:16:53 PST 2014
Markus Metz wrote:
> AFAIU, the whole discussion boils down to the question if we want to
> require a system-wide installation of Python with correct python file
> associations in the registry, potentially deactivating an existing
> Python installation, or not.
> There seems to be agreement that we do not want to modify any existing
> system-wide python installation.
> That means that WinGRASS should
> 1) not do a system-wide installation of Python
It should not blindly replace or modify any system-wide installation.
> 2) not require a system-wide Python installation
It needs a system-wide Python installation if Python scripts are to be
"first-class citizens", i.e. having the same capabilities as a
compiled program. This is an OS requirement which GRASS cannot avoid.
If you don't do this, "WinGRASS" will always be a second-class citizen
compared to the real (i.e. Unix) GRASS.
