[GRASS-dev] grass71 and GDAL read
    Jachym Cepicky
    jachym.cepicky at gmail.com
    Tue Jul  1 01:42:01 PDT 2014
Hi Huidae,
let me give you short progress report I have. I managed to configure,
make and make install the grass-gdal plugin with the patch you
provided in your last mail without problems:
./configure --with-gdal=/usr/local/bin/gdal-config
--with-grass=/usr/local/grass-7.1.svn/
make
g++ -shared  grass57dataset.o -L/usr/local/grass-7.1.svn//lib
-lgrass_gmath -lgrass_gis -lgrass_datetime -lgrass_gproj
-lgrass_vector -lgrass_dbmibase -lgrass_dbmiclient -lgrass_dgl
-lgrass_dig2 -lgrass_rtree -lgrass_linkm -L/usr/local/lib -lgdal  -o
gdal_GRASS.so
g++ -shared  ogrgrassdriver.o ogrgrassdatasource.o ogrgrasslayer.o
-L/usr/local/grass-7.1.svn//lib -lgrass_gmath -lgrass_gis
-lgrass_datetime -lgrass_gproj -lgrass_vector -lgrass_dbmibase
-lgrass_dbmiclient -lgrass_dgl -lgrass_dig2 -lgrass_rtree
-lgrass_linkm -L/usr/local/lib -lgdal  -o ogr_GRASS.so
sudo make install
install -d /usr/local/lib/gdalplugins
cp gdal_GRASS.so /usr/local/lib/gdalplugins
cp ogr_GRASS.so /usr/local/lib/gdalplugins
testing:
gdalinfo --formats|grep GRASS
  GRASS (ro): GRASS Database Rasters (5.7+)
  GRASSASCIIGrid (rov): GRASS ASCII Grid
ogrinfo --formats|grep GRASS
  -> "GRASS" (readonly)
So it seems to be working. However, runing gdalinfo on certain raster
file produces following error :-(
gdalinfo /home/grass/grassdata/prg/interpolations/cellhd/dmt
gdalinfo: symbol lookup error:
/usr/local/lib/gdalplugins/gdal_GRASS.so: undefined symbol:
Rast_get_cellhd
Strange thing: vectors (ogr2ogr, ogrinfo) on GRASS vectors works perfectly
I would say, that it's related to dynamic linker, thought, I have
$ cat /etc/ld.so.conf.d/grass-7.1.conf
/usr/local/grass-7.1.svn/lib/
and ldconfig -p |grep grass_raster gives
libgrass_raster.7.1.svn.so (libc6,x86-64) =>
/usr/local/grass-7.1.svn/lib/libgrass_raster.7.1.svn.so
libgrass_raster.so (libc6,x86-64) =>
/usr/local/grass-7.1.svn/lib/libgrass_raster.so
Any hint?
Thank you
2014-06-30 10:12 GMT+02:00 Jachym Cepicky <jachym.cepicky at gmail.com>:
> Worked, but had to add -I/usr/include/postgresql/ to CPPFLAGS
> seems to be compiled and in gdal
> thank you
> 2014-06-27 12:13 GMT+02:00 Huidae Cho <grass4u at gmail.com>:
>> Try the attached patches. The GRASS plugin works for me.
>> ./configure --with-autoload=/usr/lib/gdalplugins
>> --with-grass=/your/grass/path
>> Huidae
>> On Fri, Jun 27, 2014 at 3:11 AM, Jachym Cepicky <jachym.cepicky at gmail.com>
>> wrote:
>>> Hi Martin,
>>> ok, sorry, but I'm a bit confused from amount of patches, which are
>>> attached to the ticket and none of them seems to be working on
>>> gdal-grass-1.4.3.
>>> I'm using GRASS 7.1 btw, so I hope, that is ok in general.
>>> Could you point me please to patches, which should work with
>>> http://download.osgeo.org/gdal/gdal-grass-1.4.3.tar.gz ?
>>> Thanks
>>> 2014-06-24 22:27 GMT+02:00 Martin Landa <landa.martin at gmail.com>:
>>> > Hi,
>>> > 2014-06-24 22:09 GMT+02:00 Jachym Cepicky <jachym.cepicky at gmail.com>:
>>> >> I wanted to publish some maps via MapServer, using GDAL, like the old
>>> >> days. But I did not succeed to get it compiled with GRASS (at first
>>> >> try). What is the best way you would propose to approach?
>>> >> 1 - compile gdal withnout grass
>>> >> 2 - compile grass 7.1 with gdal support
>>> >> 3 - compile gdal again with grass support?
>>> >> It worked some years back, but does it still apply?
>>> > best is to compile GRASS driver as a plugin, anyway GRASS 7 support in
>>> > GDAL is still open issue [1].
>>> > Martin
>>> > [1] http://trac.osgeo.org/gdal/ticket/2953
>>> > Martin Landa * http://geo.fsv.cvut.cz/gwiki/Landa
>>> Jachym Cepicky
>>> e-mail: jachym.cepicky gmail com
>>> URL: http://les-ejk.cz
>>> GPG: http://les-ejk.cz/pgp/JachymCepicky.pgp
>>> grass-dev mailing list
>>> grass-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/grass-dev
> Jachym Cepicky
Jachym Cepicky
