[GRASS-dev] [GRASS GIS] #2338: r.horizon rename parameters
GRASS GIS trac at osgeo.org
Tue Jul 1 02:48:58 PDT 2014
  Reporter:  zarch        |       Owner:  grass-dev@…
      Type:  enhancement  |      Status:  closed
  Priority:  critical     |   Milestone:  7.0.0
 Component:  Raster       |     Version:  svn-trunk
Resolution:  fixed        |    Keywords:  r.horizon
  Platform:  All          |         Cpu:  All
Changes (by zarch):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Replying to [comment:11 annakrat]:
 > the rest as you suggested
 Done in [http://trac.osgeo.org/grass/changeset/61096 r61096].
 > With the new standard option, do you think
 > changing gisprompt would be a good idea? It could be
 > Opt->gisprompt = "old,cell,basename";
 > GUI could use that instead of guessing from the parameter name.
 > The widget could be the standard map selection widget but when
 > selecting the map, it could try to cut the suffix (in case we
 > have the standardized delimiter such as `__`). When new series
 > of maps are created, they could be all added (up to some number).
 +1
 yes I think that add a basename option to gisprompt could be a good idea.
 I close this ticket, we could discuss further about this in
 [https://trac.osgeo.org/grass/ticket/2136 #2136].
Ticket URL: <https://trac.osgeo.org/grass/ticket/2338#comment:12>
