[GRASS-dev] [GRASS-SVN] r60679 - grass/trunk/lib/python/script
Vaclav Petras
wenzeslaus at gmail.com
Wed Jul 2 07:59:34 PDT 2014
On Wed, Jul 2, 2014 at 10:39 AM, Martin Landa <landa.martin at gmail.com>
wrote:
> The reason is empty XML wxGUI menu file (menudata.xml) produced by
> building system, see [2].
> Traceback (most recent call last):
> File "core/toolboxes.py", line 759, in <module>
> sys.exit(main())
> File "core/toolboxes.py", line 745, in main
> userDefined=False)
> File "core/toolboxes.py", line 204, in createTree
> moduleItems=moduleItems)
> File "core/toolboxes.py", line 241, in toolboxes2menudata
> _expandRuntimeModules(root)
> File "core/toolboxes.py", line 514, in _expandRuntimeModules
> desc, keywords = _loadMetadata(name)
> File "core/toolboxes.py", line 540, in _loadMetadata
> task = gtask.parse_interface(module)
> File
> "c:\osgeo4w\usr\src\grass_trunk\dist.i686-pc-mingw32\etc\python\grass\script\task.py",
> line 501, in parse_interface
> tree = etree.fromstring(get_interface_description(name))
> File
> line 465, in get_interface_description
> stderr = PIPE)
> File
> "c:\osgeo4w\usr\src\grass_trunk\dist.i686-pc-mingw32\etc\python\grass\script\core.py",
> line 58, in __init__
> name, ext = os.path.splitext(cmd)
> File "c:/OSGeo4W/apps/Python27\lib\ntpath.py", line 190, in splitext
> return genericpath._splitext(p, sep, altsep, extsep)
> File "c:/OSGeo4W/apps/Python27\lib\genericpath.py", line 91, in _splitext
> sepIndex = p.rfind(sep)
> AttributeError: 'NoneType' object has no attribute 'rfind'
> make[4]: *** [xml/menudata.xml] Error 1
It seems that shutil_which returned None at line (from the patch):
cmd = shutil_which(args[0])
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140702/d7984111/attachment.html>
