[GRASS-dev] type of parameter resolution in g.region vs r.proj
Margherita Di Leo dileomargherita at gmail.com
Wed Jul 2 09:05:00 PDT 2014
Apparently, for unprojected reference systems, r.proj doesn't accept the
parameter resolution expressed in DD:MM:SS, but only in decimal degrees (at
least for me, any other experience?), while for example g.region does
accept this format. The type of the parameter resolution is float for
r.proj and integer for g.region (as far as i can understand digging into
the source code). My (probably naive) question is : Wouldn't it make sense
to adopt integer type also for r.proj?
Thanks for any pointers
Best regards,
Dr. Margherita DI LEO
Scientific / technical project officer
European Commission - DG JRC
Institute for Environment and Sustainability (IES)
Via Fermi, 2749
I-21027 Ispra (VA) - Italy - TP 261
Tel. +39 0332 78 3600
margherita.di-leo at jrc.ec.europa.eu
Disclaimer: The views expressed are purely those of the writer and may not
in any circumstance be regarded as stating an official position of the
European Commission.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140702/3414b3df/attachment.html>
