[GRASS-dev] [GRASS-SVN] r60679 - grass/trunk/lib/python/script
Glynn Clements
glynn at gclements.plus.com
Wed Jul 2 16:35:24 PDT 2014
Anna Petrášová wrote:
> > It's because it can't find v.in.gps. I suggest to add to the patch
> something like this:
> + def __init__(self, args, **kwargs):
> + if ( sys.platform == 'win32'
> + and isinstance(args, list)
> + and not kwargs.get('shell', False)
> + and kwargs.get('executable') is None ):
> + cmd = shutil_which(args[0])
> if cmd is None:
> raise OSError
> + args = [cmd] + args[1:]
> + name, ext = os.path.splitext(cmd)
> + if ext.lower() not in self._builtin_exts:
> + kwargs['shell'] = True
> + args = [self._escape_for_shell(arg) for arg in args]
> + subprocess.Popen.__init__(self, args, **kwargs)
Hmm; maybe:
if cmd is not None:
If shutil_which() doesn't find the command, we just leave it to
Popen() to complain about it. It's conceivable that it might even
manage to run it (I wouldn't assume that shutil_which() mimics
Windows' own handling exactly).
Ideally, I'd prefer our version of Popen to be as close to the
original as we can get away with.
Alternatively.
if cmd is not None:
else:
name, ext = None, ''
In this case, it falls back to using the shell if shutil_which()
fails, while still keeping the shell out of the way for an EXE.
