[GRASS-dev] [GRASS-SVN] r60679 - grass/trunk/lib/python/script
Wed Jul 2 16:38:51 PDT 2014
Anna Petrášová wrote:
> Running this command in gui console works but r.info gives incorrect result:
> r.support map=scanned title="|@#$%^&*()"
> and r.info gives ^^^|@#$%^^^^^^^&*()
That implies that the GUI is escaping for the shell but then either
not using the shell or overdoing the escaping.
But I'm less concerned about the GUI than about the core grass.script
functionality.
