[GRASS-dev] using rand(x,y) in r.mapcalc (grass7)
Wed Jul 2 17:15:52 PDT 2014
Paulo van Breugel wrote:
> When I run several times e.g., r.mapcalc "a = rand(0,100)"
> I am always getting exactly the same layer. In the help file it reads:
> "The environment variable GRASS_RND_SEED is read to initialize the random
> number generator"
> But what does it mean.
The value of that environment variable is parsed using atol() and the
result used to seed the PRNG (via srand() or srand48()) (setup_rand()
in r.mapcalc/evaluate.c).
If the variable isn't set, the PRNG isn't explicitly seeded. For
rand(), the result should be equivalent to GRASS_RND_SEED=1.
> Shouldn't the seed not be generated on e.g, OS time,
> which would ensure that each run would give a different result?
No. The reason is to provide reproducibility. Anyone running the same
command with the same data should obtain the same result.
If you want a different result each time, set GRASS_RND_SEED to a
different value each time, e.g.
	GRASS_RND_SEED=`date +%N` r.mapcalc "a = rand(0,100)"
[%N is the nanoseconds portion of the current time; this is a GNU
extension.]
> On a related note, it would be nice to be able to set the seed (I think
> there has been such a request before, but not sure about the answer at that
> time).
GRASS_RND_SEED was the answer.
