[GRASS-dev] [GRASS GIS] #2357: r3.info segfaults or reports incorrect values on Windows
trac at osgeo.org
Thu Jul 3 08:12:57 PDT 2014
Reporter: annakrat | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.1.0
Component: Raster3D | Version: svn-releasebranch70
Keywords: r3.info | Platform: MSWindows 8
Cpu: Unspecified |
When I run r3.info on Windows on a map computed with v.vol.rst, it's
segfaults and stops writing output after:
| Projection: Lambert Conformal Conic (zone 0)
| N: 100 S: 0 Res: 1
| E: 100 W: 0 Res: 1
When I create a random map:
g.region w=0 e=100 s=0 n=100 t=100 b=0 res=1 res3=1
r3.mapcalc "test = rand(0,100)"
it doesn't segfault but I get nonsense (I guess it's the same problem):
| N: 100 S: 0 Res: 1
| E: 100 W: 0 Res: 1
| T: 0 B: 0 Res: 0
| Range of data: min = 0 max = 0
The same map copied to linux has no problems. Perhaps the function
`format_double` could cause it since it is used for reporting top, bottom
and range values.
Further investigation shows that r.info reports wrong number of categories
(0) on a map which has categories. This would again point at
`format_double` function which looks completely the same as in r3.info.
However, v.info seems to work although it uses again `format_double`
function, but slightly modified:
r(3).info:
void format_double(const double value, char *buf)
sprintf(buf, "%.8lf", value);
G_trim_decimal(buf);
v.info:
void format_double(double value, char *buf)
sprintf(buf, "%.8f", value);
Could the `l` in the formatting make difference on Windows?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2357>
