[GRASS-dev] [GRASS GIS] #494: break in importing and cleaning very large vector datasets
GRASS GIS trac at osgeo.org
Thu Jul 3 13:33:22 PDT 2014
  Reporter:  gisboa  |       Owner:  grass-dev@…
      Type:  defect  |      Status:  reopened
  Priority:  major   |   Milestone:  6.4.0
 Component:  Vector  |     Version:  6.4.0 RCs
Resolution:          |    Keywords:  vector import clean build
  Platform:  All     |         Cpu:  All
Changes (by dido):
  * status:  closed => reopened
  * resolution:  worksforme =>
Comment:
 Same issue was observed on a large (282 MB shapefile) containing ~350 000
 polygons.
 A dump from the output window:
 Layer: BGM_Polygons_L0
 Counting polygons for 358823 features...
 Importing map 358823 features...
 483699 primitives registered
 17237143 vertices registered
 Number of nodes: 414562
 Number of primitives: 483699
 Number of points: 0
 Number of lines: 0
 Number of boundaries: 483699
 Number of centroids: 0
 Number of areas: -
 Number of isles: -
 Cleaning polygons, result is not guaranteed!
 Snap boundaries (threshold = 1.000e-005):
 G_realloc: unable to allocate 155760024 bytes at snap.c:155
 Finished with error
 System is Win7x64 with 16G of RAM. RAM usage reported was ~4.3G at max,
 dropped down to ~2.6G, then the error popped-up. Progress was at ~70%.
 This was seen first on a QGIS 2.2.0 Valmiera, same behavior was seen on
 1.8.0 Lisboa.
Ticket URL: <https://trac.osgeo.org/grass/ticket/494#comment:4>
