[GRASS-dev] [GRASS GIS] #2358: Strange behaviour with v.net on GRASS GIS 7
GRASS GIS trac at osgeo.org
Fri Jul 4 06:15:30 PDT 2014
 Reporter:  lluis                            |       Owner:  grass-dev@…
     Type:  defect                           |      Status:  new
 Priority:  normal                           |   Milestone:  7.0.0
Component:  Vector                           |     Version:  svn-releasebranch70
 Keywords:  Ubuntu 14.04, v.net, attributes  |    Platform:  Linux
      Cpu:  x86-64                           |
 I'm working with GRASS GIS 7.0.0svn (r59969) on Ubuntu 14.04 LTS and I'm
 experiencing a strange behaviour when using v.net. I have set of nodes
 that I want to connect to a collection of streets on a network.
 When I execute "v.net streets points=libraries out=net op=connect
 thresh=150" on GRASS GIS 6.4.4, the new arc(s)/line(s) that connect the
 points to the network, inherit all the attributes (even the 'cat' value)
 of the pre-existing arcs. But, when I execute the same command on GRASS
 GIS 7.0.0 that expected behaviour doesn't take place. The new
 arc(s)/line(s) generated with GRASS 7 doesn't have attributes, a new cat
 value is generated for each new line but they doesn't appear on the
 attribute table...
Ticket URL: <https://trac.osgeo.org/grass/ticket/2358>
