[GRASS-dev] [GRASS-SVN] r61051 - grass/trunk/lib/init
Huidae Cho
grass4u at gmail.com
Fri Jul 4 12:07:56 PDT 2014
Also, csh_startup() still overrides already set environment variables.
if os.access(grass_env_file, os.R_OK):
f.write(readfile(grass_env_file) + '\n')
So we have $LOCATION/.bashrc, ~/.grass7/bashrc, and ~/.grass.bashrc. Do
they all have different purposes and are they documented clearly somewhere?
On Fri, Jul 4, 2014 at 3:02 PM, Huidae Cho <grass4u at gmail.com> wrote:
> Martin,
> Please explain why we need this change. It breaks custom PS1 and aliases
> in $HOME/.grass7/bashrc.
> Thank you.
> Huidae
> On Sun, Jun 29, 2014 at 6:22 AM, <svn_grass at osgeo.org> wrote:
>> Author: martinl
>> Date: 2014-06-29 03:22:23 -0700 (Sun, 29 Jun 2014)
>> New Revision: 61051
>> Modified:
>> grass/trunk/lib/init/grass.py
>> Log:
>> grass.py: do not override already set GRASS environmental variables
>> Modified: grass/trunk/lib/init/grass.py
>> --- grass/trunk/lib/init/grass.py 2014-06-29 10:07:13 UTC (rev
>> 61050)
>> +++ grass/trunk/lib/init/grass.py 2014-06-29 10:22:23 UTC (rev
>> 61051)
>> @@ -746,7 +746,17 @@
>> k, v = map(lambda x: x.strip(), line.strip().split(' ',
>> 1)[1].split('=', 1))
>> except:
>> continue
>> - os.environ[k] = v
>> + evalue = os.getenv(k)
>> + if evalue:
>> + if k == 'GRASS_ADDON_PATH':
>> + os.environ[k] = evalue + os.pathsep + v
>> + else:
>> + warning(_("Environmental variable '%s' already set,
>> ignoring value '%s'") % \
>> + (k, v))
>> + else:
>> + os.environ[k] = v
>> # Allow for mixed ISIS-GRASS Environment
>> if os.getenv('ISISROOT'):
>> isis = os.getenv('ISISROOT')
>> @@ -1131,8 +1141,14 @@
>> path = os.path.join(userhome, ".grass.bashrc") # left for backward
>> compatibility
>> if os.access(path, os.R_OK):
>> f.write(readfile(path) + '\n')
>> - if os.access(grass_env_file, os.R_OK):
>> - f.write(readfile(grass_env_file) + '\n')
>> + for env in os.environ.keys():
>> + if env.startswith('GRASS'):
>> + val = os.environ[env]
>> + if ' ' in val:
>> + val = '"%s"' % val
>> + f.write('export %s=%s\n' % (env, val))
>> + # if os.access(grass_env_file, os.R_OK):
>> + # f.write(readfile(grass_env_file) + '\n')
>> f.write("export PATH=\"%s\"\n" % os.getenv('PATH'))
>> f.write("export HOME=\"%s\"\n" % userhome) # restore user home path
>> grass-commit mailing list
>> grass-commit at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-commit
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140704/86e894eb/attachment.html>
