[GRASS-dev] [GRASS-SVN] r61051 - grass/trunk/lib/init
Martin Landa landa.martin at gmail.com
Wed Jul 9 04:44:21 PDT 2014
2014-07-04 21:02 GMT+02:00 Huidae Cho <grass4u at gmail.com>:
> Please explain why we need this change. It breaks custom PS1 and aliases in
> $HOME/.grass7/bashrc.
sorry for late answer, the original reason was:
1) you have defined GRASS_ADDON_PATH in $HOME/.grass7/bashrc
2) you launch GRASS with $ GRASS_ADDON_PATH=~/bin/md-iso grass71
GRASS_ADDON_PATH points just to the path from `$HOME/.grass7/bashrc`.
The patch enables to merge paths from $HOME/.grass7/bashrc together
with `~/bin/md-iso`. I was not aware of aliases, you are absolutely
right, I will fix it ASAP. Martin
Martin Landa * http://geo.fsv.cvut.cz/gwiki/Landa
