[GRASS-dev] [GRASS-SVN] r61236 - grass/trunk/gui/wxpython/lmgr
Vaclav Petras
wenzeslaus at gmail.com
Thu Jul 10 12:11:19 PDT 2014
the original motivation for the commit was actually terminology. When
talking about the raster/vector/3D raster file on disk, we should use "map"
rather then "layer" to be consistent with the rest of GRASS. Let me know if
you think otherwise.
Vaclav
PS: You were silent for some time so I took the liberty to edit the code.
PPS: I've used the data catalog for the first time. It is pretty cool!
On Thu, Jul 10, 2014 at 3:03 PM, <svn_grass at osgeo.org> wrote:
> Author: wenzeslaus
> Date: 2014-07-10 12:03:00 -0700 (Thu, 10 Jul 2014)
> New Revision: 61236
> Modified:
> grass/trunk/gui/wxpython/lmgr/datacatalog.py
> Log:
> wxGUI/datacatalog: use GRASS standard message format with <>, use string
> formatting instead of plus (to enable good translations), use keyword
> arguments when parameter names are unclear, prefer shorter lines
> Modified: grass/trunk/gui/wxpython/lmgr/datacatalog.py
> --- grass/trunk/gui/wxpython/lmgr/datacatalog.py 2014-07-10
> 18:51:58 UTC (rev 61235)
> +++ grass/trunk/gui/wxpython/lmgr/datacatalog.py 2014-07-10
> 19:03:00 UTC (rev 61236)
> @@ -402,7 +402,9 @@
> string = self.GetItemText(self.selected_layer)
> self.ChangeEnvironment(self.GetItemText(self.selected_location),
> self.GetItemText(self.selected_mapset))
> removed = 0
> - if (self._confirmDialog(_('Do you really want to delete
> layer') +string+'?', _('Delete map')) == wx.ID_YES):
> + # TODO: rewrite this that it will tell map type in the dialog
> + if (self._confirmDialog(question=_('Do you really want to
> delete map <{m}>?').format(m=string),
> + title=_('Delete map')) == wx.ID_YES):
> label = _("Deleting") + " " + string + " ..."
> self.showNotification.emit(message=label)
> if (self.GetItemText(self.selected_type)=='vect'):
> grass-commit mailing list
> grass-commit at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-commit
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140710/e60e76c2/attachment.html>
