[GRASS-dev] [GRASS GIS] #2363: Temporal datasets in a mapset are not visible when the mapset is renamed
GRASS GIS trac at osgeo.org
Fri Jul 11 10:26:48 PDT 2014
 Reporter:  annakrat     |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  normal       |   Milestone:  7.1.0
Component:  Temporal     |     Version:  svn-trunk
 Keywords:  mapset       |    Platform:  All
      Cpu:  Unspecified  |
Comment(by huhabla):
 This is a limitation that is not easy to fix. The module t.list will show
 only those stds from mapsets you have access to. If you rename a mapset,
 the ids of the stds will still build upon the original mapset name and
 therefor this mapset will be unknown to GRASS. Hence, if you rename a
 mapset you have to access the temporal database by your tool of choice and
 modify the mapset and id columns of the stds and map tables. In worst case
 you need to modify 5 tables with SQL staments to rename the mapset.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2363#comment:1>
