[GRASS-dev] [GRASS GIS] #2365: gunittest test local input file failure
GRASS GIS trac at osgeo.org
Sat Jul 12 03:51:13 PDT 2014
 Reporter:  huhabla              |       Owner:  grass-dev@…
     Type:  defect               |      Status:  new
 Priority:  major                |   Milestone:  7.1.0
Component:  Default              |     Version:  svn-trunk
 Keywords:  gunittest,testsuite  |    Platform:  Linux
      Cpu:  x86-64               |
 gunittest does not recognize local input files for tests when run with
 grass.gunittest.main invokation.
 I have added a test for r.series.interp (r61239) that requires input files
 in the testsuite directory.
 The unittest includes module failure tests and tests with input files.
 When i run the test from the command line, everything is fine:
 GRASS 7.1.svn
 (LL):~/src/grass7.1/grass_trunk/raster/r.series.interp/testsuite >ls -l
 -rw-rw-r-- 1 soeren soeren   40 Jul 12 11:28 infile_2.txt
 -rw-rw-r-- 1 soeren soeren 4059 Jul 12 12:35 interp_test.py
 -rw-rw-r-- 1 soeren soeren   41 Jul 12 11:28 outfile_1.txt
 -rw-rw-r-- 1 soeren soeren   60 Jul 12 11:28 outfile_2.txt
 -rw-rw-r-- 1 soeren soeren   30 Jul 12 11:28 outfile_corrupt.txt
 GRASS 7.1.svn
 (LL):~/src/grass7.1/grass_trunk/raster/r.series.interp/testsuite > python
 interp_test.py
  100%
  100%
  100%
  100%
  100%
  100%
  100%
  100%
  100%
  100%
  100%
  100%
 ERROR: Please specify output= or outfile=
 ERROR: Please specify output= and samplingpos=
 ERROR: output= and outfile= are mutually exclusive
 ERROR: samplingpos= and outfile= are mutually exclusive
 ERROR: Unable to open output file <mo_such_file>
 ERROR: Missing point position for output map <prec_4> in file
        <outfile_corrupt.txt> near line 2
 Ran 4 tests in 1.205s
 OK
 The input files are not found when i invoke the same test with the
 grass.gunittest.main method:
 GRASS 7.1.svn (LL):~/src/grass7.1/grass_trunk/raster/r.series.interp >
 python -m grass.gunittest.main ~/grassdata LAEA_ERTS89 LAEA_ERTS89
 ./interp_test failed (see testreport/./interp_test/index.html)
 GRASS 7.1.svn (LL):~/src/grass7.1/grass_trunk/raster/r.series.interp > cat
 testreport/./interp_test/stderr.txt .FF.
 FAIL: test_infile (__main__.InterpolationTest)
   File
 "/home/soeren/src/grass7.1/grass_trunk/raster/r.series.interp/testsuite/interp_test.py",
 line 47, in test_infile
     outfile="outfile_1.txt",  method="linear")
   File "/home/soeren/src/grass7.1/grass_trunk/dist.x86_64-unknown-linux-
 gnu/etc/python/grass/gunittest/case.py", line 519, in assertModule
     self.fail(self._formatMessage(msg, stdmsg))
 AssertionError: Running <r.series.interp> module ended with non-zero
 return code (1)
 Called: r.series_interp(input=['prec_1,prec_5'], datapos=[0.0, 1.0],
 outfile='outfile_1.txt', method='linear')
 See the folowing errors:
 ERROR: Unable to open output file <outfile_1.txt>
 FAIL: test_inoutfiles (__main__.InterpolationTest)
   File
 line 55, in test_inoutfiles
     outfile="outfile_2.txt",  method="linear")
 return code (1)
 Called: r.series_interp(infile='infile_2.txt', outfile='outfile_2.txt',
 method='linear')
 ERROR: Unable to open input file <infile_2.txt>
 Ran 4 tests in 1.059s
 FAILED (failures=2)
Ticket URL: <http://trac.osgeo.org/grass/ticket/2365>
