[GRASS-dev] Week 8: GRASS GIS 3D flowlines
Sören Gebbert
soerengebbert at googlemail.com
Sat Jul 12 06:10:14 PDT 2014
Hi Anna,
your results are impressive. I have tested the r3.flow module with
artificial groundwater flow data and Paraview (see the attached script
that generates the data). Your flowpaths are looking exactly like the
ones generated with the VTK streamtracer, see the attached
screenshots[1,2].
The red lines are the VTK streamtracer paths[1], the white lines are the
r3.flow downstream and upstream paths[2]. I have generated 300 sample
points with v.random near the location of the Paraview streamtracer
sample line (see attached script) to generate similar path lines.
Great work indeed,
Best regards
Soeren
[1] https://www-pool.math.tu-berlin.de/~soeren/grass/Paraview_r3_flow_streamtracer.png
[2] https://www-pool.math.tu-berlin.de/~soeren/grass/Paraview_r3_flow_streams.png
2014-07-11 23:22 GMT+02:00 Anna Petrášová <kratochanna at gmail.com>:
> Hi,
> 1. What did you get done this week:
> I have now a working C implementation of the r3.flow module with
> functionality limited to generating flow lines [2].
> 2. What do you plan on doing next week?
> I will continue with the C implementation (flow accumulation, gradient
> computation)
> 3. Are you blocked on anything?
> No.
> Anna
> [1]
> http://trac.osgeo.org/grass/wiki/GSoC/2014/ImplementationOf3DRasterFlowLine
> [2] http://trac.osgeo.org/grass/browser/grass-addons/grass7/raster3d/r3.flow
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
Type: application/x-sh
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140712/690dd47c/attachment.sh>
