[GRASS-dev] GRASS 70 compilation error linux Mint 13
Roberto Marzocchi roberto.marzocchi at gmail.com
Wed Jul 16 03:30:56 PDT 2014
This is my error.log file:
GRASS GIS 7.0.0svn r61251 compilation log
Started compilation: mer 16 lug 2014, 11.49.02, CEST
Errors in:
/home/localop/Dati/source_code/grass70_release/lib/python/ctypes
/home/localop/Dati/source_code/grass70_release/db/drivers/dbf
/home/localop/Dati/source_code/grass70_release/db/drivers/postgres
/home/localop/Dati/source_code/grass70_release/db/drivers/mysql
/home/localop/Dati/source_code/grass70_release/db/drivers/sqlite
/home/localop/Dati/source_code/grass70_release/db/drivers/ogr
/home/localop/Dati/source_code/grass70_release/gui/wxpython/animation
/home/localop/Dati/source_code/grass70_release/gui/wxpython/mapswipe
/home/localop/Dati/source_code/grass70_release/gui/wxpython/gmodeler
/home/localop/Dati/source_code/grass70_release/gui/wxpython/rlisetup
/home/localop/Dati/source_code/grass70_release/gui/wxpython/psmap
/home/localop/Dati/source_code/grass70_release/gui/wxpython/dbmgr
/home/localop/Dati/source_code/grass70_release/gui/wxpython/vdigit
/home/localop/Dati/source_code/grass70_release/gui/wxpython/iclass
/home/localop/Dati/source_code/grass70_release/gui/wxpython/gcp
/home/localop/Dati/source_code/grass70_release/gui/wxpython/timeline
/home/localop/Dati/source_code/grass70_release/visualization/wximgview
/home/localop/Dati/source_code/grass70_release/man
In case of errors please change into the directory with error and run
'make'.
If you get multiple errors, you need to deal with them in the order they
appear in the error log. If you get an error building a library, you will
also get errors from anything which uses the library.
Finished compilation: mer 16 lug 2014, 11.49.56, CEST
Anyone have experience with these errors?
Thanks in advanced for the attention
R
Un allegato HTML � stato rimosso...
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140716/7db04df7/attachment.html>
