[GRASS-dev] [GRASS GIS] #1787: Profile Analysis Tool Problems
trac at osgeo.org
Thu Jul 17 14:33:03 PDT 2014
Reporter: stu | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 7.1.0
Component: wxGUI | Version: svn-trunk
Keywords: profile tool r.profile | Platform: All
Cpu: x86-64 |
Comment(by annakrat):
Replying to [comment:9 annakrat]:
> Replying to [comment:7 dadudeman]:
> > Used r.profile interactively in GRASS 7.1 SVN. Same problems
described by stu. If I use horizontal and vertical units of meters, the
plot is perfect. If I change to horizontal and vertical units of feet,
the Y axis of elevations is displayed correctly, but the X axis is
squished to stop at the unit value in meters rather than feet. Example:
I had a 800 meter transect, but when reprojected to feet and profiled, the
graph stops at 800 feet rather than the approximate 2600. The endpoint
triangle, however, is placed around the 2600 distance. It's as if it
thinks the units are meters horizontal.
> Yes, it's meters because meters come from r.profile and the GUI
profiling tool just takes the values as they are. I wonder if this should
be changed in r.profile rather than in the GUI?
I fixed this problem in GUI (r61269). Please test. Still it would be worth
changing the behavior of r.profile (and then revert this commit).
Ticket URL: <http://trac.osgeo.org/grass/ticket/1787#comment:11>
