[GRASS-dev] [GRASS GIS] #2286: Duplicate calls to d.rast when using wx monitor and d.rast command line
trac at osgeo.org
Thu Jul 17 15:04:23 PDT 2014
Reporter: hcho | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 7.0.0
Component: Display | Version: svn-trunk
Keywords: d.mon | Platform: Linux
Cpu: x86-64 |
Comment(by wenzeslaus):
Replying to [ticket:2286 hcho]:
> IMO, to avoid duplicate calls to d.rast, if we call d.rast from the
command line and the selected monitor is wx, it should simply add d.rast
commands to the command file and let the monitor handle actual drawing.
Hm, I actually thought that this is how it was designed and what it is
doing. I this is the case, then what you are saying is clear bug and you
can safely fix it.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2286#comment:3>
