[GRASS-dev] [GRASS GIS] #1972: v.in.ogr wrapper fails with UnicodeEncodeError
trac at osgeo.org
Fri Jul 18 01:02:57 PDT 2014
Reporter: marisn | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 7.0.0
Component: wxGUI | Version: svn-trunk
Keywords: | Platform: Unspecified
Cpu: Unspecified |
Comment(by marisn):
Replying to [comment:3 annakrat]:
> The problem was with translatable string "Yes" or "No" which is inserted
into the list to describe if projection is matching. I removed the str
function in r61271. Needs testing also for English locale.
Tested on my lv_LV.UTF-8 Linux system with current trunk - works fine.
Thank you, Anna.
Needs a backport to 7.0 branch?
Ticket URL: <http://trac.osgeo.org/grass/ticket/1972#comment:4>
