[GRASS-dev] [GRASS GIS] #1288: g.dirseps breaks non-latin file/folder names on Windows
trac at osgeo.org
Fri Jul 18 01:59:07 PDT 2014
Reporter: marisn | Owner: grass-dev@…
Type: defect | Status: closed
Priority: critical | Milestone: 7.0.0
Component: Default | Version: 6.4.1 RCs
Resolution: fixed | Keywords: wingrass, i18n, encoding
Platform: MSWindows Vista | Cpu: Unspecified
Changes (by marisn):
* status: new => closed
* resolution: => fixed
Comment:
Closing, as GRASS 7 has moved away from the TCL/Tk UI, startup script now
is using Python and doesn't call dirseps via shell.
The encoding issues when passing text via CMD remain, but are (and should
be) tracked in separate tickets. It is still an issue for the 6.x
releases, but wontfix there due to too invasive changes required.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1288#comment:5>
