[GRASS-dev] <gsoc2014> <grass metadata> <week 9>
Matej Krejci
matejkrejci at gmail.com
Fri Jul 18 10:03:20 PDT 2014
Hi all,
Below is my weekly report:
*<work done>*
- mainly implemented 'metadata multiplicity button' for dynamically
adding widgets and also removing it
- finished support of exporting metadata from dynamically generated GUI
(multiplicity button) (need more working to allow exporting keywords to xml
(multiple keywords))
- partially connected finished modules together (g.gui.metadata) [1]
- validator
- tree editor
- main editor
- toolbox
*<work to be done in the next week>*
- to finish connection between modules
- to change current map catalog(left side) for grass
"datacatalog.py"[2]
- to fix exporting of metadata-keywords added by 'multiplicity button to
static box' to xml.
- to start on implementation of multiple editing metadata of maps
- to connect v.info.iso, r.info.iso to g.gui.metadata
- testing
*<blocks>*
no
Best,
Matej
[1]
http://trac.osgeo.org/grass/attachment/wiki/GSoC/2014/MetadataForGRASS/g.gui.metadata1.jpg
[2] http://grass.osgeo.org/programming7/datacatalog_8py_source.html
------------- dal�� ��st ---------------
HTML p��loha byla odstran�na...
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140718/44e365e1/attachment.html>
