[GRASS-dev] GRASS 7.1 trunk file man file error
Maris Nartiss
maris.gis at gmail.com
Fri Jul 18 23:46:22 PDT 2014
Just for the record. This is the issue #2370
https://trac.osgeo.org/grass/ticket/2370
Maris.
2014-07-19 0:19 GMT+03:00 Glynn Clements <glynn at gclements.plus.com>:
> Michael Barton wrote:
>> Just now compiled GRASS 7.1 trunk and got an error in the man file
>> /Users/cmbarton/Dropbox/GRASS_dropbox/source/grass7_dev/dist.x86_64-apple-darwin13.3.0/docs/html/keywords.html:16:0:
>> Error (IndexError('pop from empty list',)):
>> <dt><b><h2>SYNOPSIS</h2></b></dt>
> <h2> isn't permitted inside <dt>.
> More generally, <dt> only allows inline elements as descendants, and
> <h2> is a block element.
> However, keywords.html is auto-generated, so this would appear to be
> either an issue with the man/build_keywords.py script, or the HTML
> files which it is using.
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
