[GRASS-dev] [GRASS GIS] #1787: Profile Analysis Tool Problems
trac at osgeo.org
Sat Jul 19 10:57:08 PDT 2014
Reporter: stu | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 7.1.0
Component: wxGUI | Version: svn-trunk
Keywords: profile tool r.profile | Platform: All
Cpu: x86-64 |
Comment(by annakrat):
Replying to [comment:13 mlennert]:
> This immediately raises once again the question of whether such
temporary workaround fixes are really a good idea, especially when we know
that a fix is actually needed elsewhere. Now that this actually seems to
work, the needed fix is in risk of oblivion.
Well, I tried to fix it in r.profile, but I failed. I couldn't find a
correct way to get the meter-whateverfeet conversion. The problem is that
in the US they apparently use FootUS instead of feet, so the standard
grass mechanism for handling units fails to recognize it as feet. (Survey
foot = 0.3048006096, international foot = 0.3048). g.proj, on the other
hand, gives correct conversion.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1787#comment:14>
