[GRASS-dev] Rast3d_location2coord inconsistent behavior
Sören Gebbert
soerengebbert at googlemail.com
Sun Jul 20 09:04:28 PDT 2014
2014-07-20 6:10 GMT+02:00 Anna Petrášová <kratochanna at gmail.com>:
> On Sat, Jul 19, 2014 at 6:30 PM, Sören Gebbert
> <soerengebbert at googlemail.com> wrote:
>> Hi Anna,
>> 2014-07-19 19:04 GMT+02:00 Anna Petrášová <kratochanna at gmail.com>:
>> > Hi,
>> > I have a question about Rast3d_location2coord [1]. It is casting the
>> > col,
>> > row, depth values to integer like this:
>> > (int) col
>> > instead of using
>> > (int)floor(col)
>> > as a result, col = 0.1 => col = 0 and col = -0.1 => col = 0, which
>> > doesn't
>> > seem correct to me. Any opinions?
>> I totally agree that there should be a function that returns the row,
>> col and depth as double values, so the developer can decide how to
>> handle these values. Otherwise there would be no convenient way to
>> determine where coordinates are located in the voxel.
>> But i am not sure if the integer casting is a bug, since the
>> Rast_easting_to_col() /Rast_northing_to_row() docs suggest integer
>> casting as conversion method. There are algorithms in GRASS that use
>> only integer casting and algorithms that make use of rounding with
>> floor() before casting to integer.
>> The problem arise in case of negative column,row or depth values when
>> casting to integer without rounding to an integer smaller than the
>> double number. So the question is are there any chances to receive
>> negative cols,rows and depths?
>> It does not seems do to me for col and row, since in case of negative
>> coordinates will west and south always be smaller than east and north,
>> resulting in always positive cols and rows. And the same should be
>> true for depths, unless the top is smaller than bottom.
> Yes, but you still can get negative col, for example when looking for the
> neighboring voxels of a voxel on the edge of the 3D raster. Then, the
> inconsistency causes problem.
Good point, i have updated the Rast3d_location2coord() function to use floor.
Best regards
Soeren
> Thanks a lot for implementing Rast3d_location2coord_double.
> Anna
>> Best regards
>> Soeren
>> > Thanks, Anna
>> > BTW, similar function Rast_northing_to_row from raster library returns
>> > double.
>> > [1] http://grass.osgeo.org/programming7/region_8c_source.html#l00291
>> > _______________________________________________
>> > grass-dev mailing list
>> > grass-dev at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/grass-dev
