[GRASS-dev] PROJSHARE changed to /usr/share/proj from /usr/local/share/proj
Markus Neteler neteler at osgeo.org
Mon Jul 21 06:46:49 PDT 2014
just FYI: since PROJ4.8 is now widely available and standard, I have
taken liberty to change configure[.in]
from
PROJSHARE=/usr/local/share/proj
to
PROJSHARE=/usr/share/proj
which results now in:
--with-proj-share=/usr/share/proj
being used by default.
Rationale:
This helps to avoid an ugly error message in the location wizard (EPSG
dialog) when GRASS wasn't explicitly compiled with --with-proj-share.
If no objections, I'll backport r61296 to relbr70.
Markus
