[GRASS-dev] [GRASS GIS] #2314: output r.out.xyz
GRASS GIS trac at osgeo.org
Mon Jul 21 18:10:17 PDT 2014
 Reporter:  pvanbosgeo                           |       Owner:  grass-dev@…
     Type:  defect                               |      Status:  new
 Priority:  normal                               |   Milestone:  7.0.0
Component:  Default                              |     Version:  svn-trunk
 Keywords:  separator, pipe, r.out.xyz, r.stats  |    Platform:  MSWindows 7
      Cpu:  All                                  |
Comment(by wenzeslaus):
 Now relates to [http://lists.osgeo.org/pipermail/grass-
 dev/2014-July/069871.html discussion] ([http://osgeo-
 org.1560.x6.nabble.com/Re-GRASS-SVN-r60679-grass-trunk-lib-python-script-
 td5143645i20.html nabble) for r60679 because "`shell=True`" is used as a
 part of the proposed solution.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2314#comment:32>
