[GRASS-dev] [GRASS GIS] #2147: db.databases not working in GRASS 7
trac at osgeo.org
Tue Jul 22 10:13:39 PDT 2014
Reporter: cmbarton | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Database | Version: svn-trunk
Keywords: db.databases, sqlite | Platform: All
Cpu: OSX/Intel |
Comment(by cmbarton):
I just checked and the behavior is the same as I originally reported. I've
run this from a mapset in my nc_spm_08 location that has a functioning
SQLITE database. That is, this mapset has vectors connected to an SQLITE
database that is working correctly. Yet I still get:
db.databases location=nc_spm_08nc_spm_08
dbmi: db_list_databases() not implemented
ERROR: Unable to list databases. Try to define correct connection settings
by db.login.
The manual defines "location" as follows:
"Default location for SQLite driver is the full path for the current
mapset. For PostgreSQL driver it's empty connection string. "
This is NOT standard usage of the word "location" in GRASS. Nonetheless,
it doesn't seem to work when I put in the proper pathname either.
db.databases location=$GISDBASE/$LOCATION_NAME/$MAPSET
by db.login.
Same thing happens if I specify the path to the SQLite database itself:
db.databases location=$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/sqlite.db
by db.login.
Maybe the command is no longer relevant. If it doesn't work, maybe it
should be dropped from the distribution.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2147#comment:11>
