[GRASS-dev] compiling grass 7 fails, complains about not finding gdal (which however is there)
Markus Neteler neteler at osgeo.org
Wed Jul 23 05:38:20 PDT 2014
On Wed, Jul 23, 2014 at 2:18 PM, Paulo van Breugel
<p.vanbreugel at gmail.com> wrote:
> I am trying to compile grass 7, with configuration settings:
> ./configure --prefix=/usr/local/grass7 --enable-64bit --with-libs=/lib64
> --with-sqlite --with-odbc --with-cairo --with-geos --with-cxx=yes
> --with-gdal=/usr/bin/gdal/bin/
                             ^^^^^^^^^^^^^^^^? -- take out "gdal/" perhaps?
> It stops halfway, with  the error message below:
> checking for gdal-config... /usr/local/gdal/bin/gdal-config
It will likely be in
/usr/local/bin/gdal-config
Hope this helps,
Markus
