[GRASS-dev] using rand(x,y) in r.mapcalc (grass7)
Anna Petrášová
kratochanna at gmail.com
Wed Jul 23 11:59:10 PDT 2014
On Tue, Jul 22, 2014 at 10:07 PM, Anna Petrášová <kratochanna at gmail.com>
wrote:
> On Tue, Jul 22, 2014 at 8:14 PM, Glynn Clements <glynn at gclements.plus.com>
> wrote:
>> Glynn Clements wrote:
>> > I'm inclined to add both an option (to specify a seed, replacing the
>> > environment variable) and a flag (to seed from the system clock or
>> > whatever), and having the PRNG generate a fatal error if neither of
>> > those are used.
>> This is now done.
>> r61350 adds the lrand48/mrand48/drand48 equivalents to lib/gis. Brief
>> testing suggests that the results are identical to those generated by
>> GNU libc (which should be identical to any other POSIX implementation).
>> r61352 changes it to generate a fatal error if used prior to seeding.
>> r61353 changes r.mapcalc so that seeding is performed via seed= or -s.
>> The seed (whether specified by seed= or generated for -s) is added to
>> the history (for r.mapcalc; r3.mapcalc's create_history() function is
>> a stub; do 3D rasters have history?)
>> Note that GRASS_RND_SEED is no longer supported. That was a hack from
>> the time before r.mapcalc used G_parser().
>> As I write this, it has occurred to me that the behaviour of rand()
>> may be non-deterministic in the presence of certain forms of
>> parallelism, e.g. multiple occurences of rand() in the expression(s)
>> in conjunction with pthreads. Ultimately we may need to expand the
>> PRNG to support explicit state (as per erand48, nrand48 and jrand48).
> I added the support for -s and seed to the r.mapcalc gui in 61354. Testing
> is very welcome.
> I wonder if there are any modules in core or addons which need to be
> updated.
For example all TGRASS tests are affected.
> Anna
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140723/57907260/attachment.html>
