[GRASS-dev] [GRASS GIS] #2379: g.gui.animation causes fatal IO error 11 (Resource temporarily unavailable) on X server
GRASS GIS trac at osgeo.org
Thu Jul 24 07:58:18 PDT 2014
on X server
 Reporter:  wenzeslaus                                                              |       Owner:  grass-dev@…
     Type:  defect        |      Status:  new
 Priority:  normal        |   Milestone:  7.1.0
Component:  wxGUI        |     Version:  svn-trunk
 Keywords:  crash, data loss, rendering, m.nviz.image, 3D, g.gui.animation, d.rast  |    Platform:  Linux
      Cpu:  Unspecified                                                             |
 Time to time g.gui.animation crashes the the whole user graphical session.
 The error is appearing randomly and I'm not able to reproduce it now
 although I got it yesterday and few months ago, too.
 I got the error with different data and on two different computers (on
 Fujitsu laptop another Dell desktop) both running Ubuntu 14.04 with Unity
 (which uses Compiz). I think that few months ago I got it also with Ubuntu
 12.04.
 The results seems to be different. Once the session was frozen but the
 computer was running. Another time the graphical session was ended and
 login screen appeared.
 I got the error when I had two animations in the animation tool but I'm
 not sure if this is really the cause. I'm also not sure if the problem is
 in 2D rendering, 3D rendering or wxPython. For example, it seemed to me
 that it is related to `m.nviz.image` but one 3D animation was rendered
 successfully and adding second animation which was 2D caused the crash.
 Here are the last error messages are (obtained by redirecting to a file).
 Honestly, I'm not sure if I used only `DEBUG=5` or also `WX_DEBUG=5`. This
 is few months old when I was able to repeated more than once. I'm not able
 to reproduce it now, although I got it.
 D1/5: grass.script.core.start_command(): m.nviz.image --o
 transparency_value=0 position=0.58,0.87 format=ppm light_ambient=100
 resolution_fine=1 light_color=255:255:255 light_position=0.2,-0.79,0.98
 focus=2039,795,650 shininess_value=60.0 twist=0 bgcolor=255:255:255
 color_map=elevlid_hourly_172_glob_11.50 at foss4g_solar perspective=19
 elevation_map=elevlid_10_20_3ft at cc_lidar2013_solar
 output=/media/.../grassdata/nc_spf/foss4g_solar/.tmp/vubu32/4374.0/b64a48a130d2926bd13099cf559930db3fa3756d
 light_brightness=36 height=4985 zexag=1.0 size=796,472
 color_map=elevlid_hourly_172_glob_11.00 at foss4g_solar perspective=19
 output=/media/.../grassdata/nc_spf/foss4g_solar/.tmp/vubu32/4374.0/aaf4dea3de504f40a5e251276126643357fac133
 D3/5: GS_ready_draw
 D3/5: GS_get_zrange(): min=280.89 max=503.013
 D3/5: GS_get_aspect(): left=0, right=795, top=471, bottom=0
 D3/5: GS_done_draw
 D3/5: GS_done_draw
 GRASS_INFO_MESSAGE(4462,4): m.nviz.image complete. File
 </media/.../grassdata/nc_spf/foss4g_solar/.tmp/vubu32/4374.0/f27c2642e0e5d71fbba04e6551611f507e5fe06a.ppm>
 created.
 GRASS_INFO_END(4462,4)
 XIO:  fatal IO error 11 (Resource temporarily unavailable) on X server
 ":0.0"
       after 562 requests (562 known processed) with 0 events remaining.
 D2/5: G_file_name(): path = /media/.../grassdata/nc_spf/foss4g_solar
 I wanted to collect more information before reporting but now I got it on
 different machine and I was not able to get more information. First I also
 thought that it is a local hardware problem but now I got it with
 different machine, although both are running the same system, Ubuntu
 14.04.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2379>
