[GRASS-dev] [GRASS-user] pygrass: Region.set_current() doesn't work
Pietro
peter.zamb at gmail.com
Fri Jul 25 02:05:11 PDT 2014
Hi Martin,
On Fri, Jul 25, 2014 at 10:39 AM, Martin Zbinden
<martin.zbinden at gmail.com> wrote:
> If I understand correctly, Region.set_current() can be used
> to effectively change the region currently used by GRASS. But changing
> extent of Raster()-object and executing set_current() does not have
> any effect.
I found the same thing some months ago:
https://lists.osgeo.org/pipermail/grass-dev/2014-February/067543.html
as explained by Vaclav:
"If you change region in C or using ctypes in Python, it is affecting
only the current process."
best regards
Pietro
