[GRASS-dev] [GRASS GIS] #2380: d.legend "use" argument makes legend disappear
    trac at osgeo.org
    Fri Jul 25 12:13:53 PDT 2014
 Reporter:  cmbarton     |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  normal       |   Milestone:  7.1.0
Component:  Display      |     Version:  svn-trunk
 Keywords:  d.legend     |    Platform:  Unspecified
      Cpu:  Unspecified  |
Comment(by annakrat):
 Replying to [ticket:2380 cmbarton]:
 > If I put a list of values into d.legend use= , the legend disappears in
 the GUI and the attribute GUI cannot be opened again. Not sure if this is
 a d.legend problem, a GUI problem, or a combination.
 It disappears when the values are out of the range of the raster map. Look
 in console for an error, it might be the case. You can display again a
 legend when you click on show/hide (twice, first as hide, second for
 show).
Ticket URL: <http://trac.osgeo.org/grass/ticket/2380#comment:2>
