[GRASS-dev] Using the new s flag or seed option for r.mapcalc in a python script
Sat Jul 26 15:15:06 PDT 2014
Anna Petrášová wrote:
> > > How do I use this new flag / seed parameter for r.mapcalc in python
> > > scripts?
> > I'll update the Python interface.
> How? If we change the interface, I would like to be able to also pass env
> to write_command.
Do you mean passing arbitrary environment variables through
grass.script.mapcalc() down to the underlying r.mapcalc command?
Which environment variables would be useful?
